by davla » Wed Mar 27, 2019 9:14 pm
Refitting leg-shields to my S3 Special...do the 4 deep nuts go on the outer runners? If not, where do they go pls? Thx
davla
by Knowledge » Wed Mar 27, 2019 10:06 pm
I think the four deep nuts you mention are used to secure the outside of the rear foot boards, not the leg shields.
Try the nuts on the moulded-in bolts in the outer plastic runners in the pack of floor runners. See if the nuts fit.
by davla » Wed Mar 27, 2019 10:44 pm
Knowledge wrote:I think the four deep nuts you mention are used to secure the outside of the rear foot boards, not the leg shields.
I guess that makes more sense as they'd make removing the rear boards easier than using the small nuts
davla
by landybretta » Thu Mar 28, 2019 9:21 am
I believe they are for the front outer legshield plastic strips. They should have a slot in them so as to be able to use a screwdriver in the confined space.
landybretta
Users browsing this forum: nastro azzurro and 53 guests
