Clutch flange
I've bought an early li/sx clutch flange (pressure plate) by mistake, can I cut away the bar underneath , to convert to a later one
https://ilambretta.co.uk/forum/
Scooterdude wrote:Yes. Just chop it off, although the pin is hardened so you won’t be able to use a hack saw. I used a die grinder to do the one i recently did. Good luck.
Jim wrote:Scooterdude wrote:Yes. Just chop it off, although the pin is hardened so you won’t be able to use a hack saw. I used a die grinder to do the one i recently did. Good luck.
Just double checking i mean the stem underneath so it turns it into a later li one, not the top pin
