by Tony Hart » Thu Dec 27, 2018 4:03 pm
Swapped the boss on a flywheel, mainly to avoid adding to my Lambretta themed door stops. I’ve drilled and tapped the flywheel and backing plate on the new boss and used high tensile M6 button headed bolts (with thread lock). Should I also use a nyloc nut on the inside? There might just be enough thread to get one on.
Tiny
Tony Hart
by Knowledge » Thu Dec 27, 2018 5:36 pm
I don’t know, but I think a nylon would hit the coils and make a mess of the stator.
Try one nut, and fit the flywheel, very carefully.
by gaz_powell » Thu Dec 27, 2018 6:02 pm
Last ones I did I put the buttonheads in from the inside and a nylocs on the outside - belt and braces
by Dazts1 » Thu Dec 27, 2018 8:08 pm
I also did the same as you Gaz. Nyloc’s to the outside. Less chance of nuts flying off and destroying your stator !
by Tony Hart » Thu Dec 27, 2018 8:33 pm
Cheers Gents. Just swapped so the nylocs are on the outside. Just need to get the engine out and swap the crank now!
Tony Hart
by dickie » Thu Dec 27, 2018 9:55 pm
Leading on.....
Can you fit a gp boss to a 4 magnet flywheel?
by dickie » Thu Dec 27, 2018 9:58 pm
What's the point in nylocs?
The main issue is shear strength which 10.9 screws have in spades. Studlock adresses the issue of screws vibrating out.
by Tony Hart » Thu Dec 27, 2018 10:01 pm
dickie wrote:What's the point in nylocs?
The technical answer to that question is ‘because I’ve got some’
Tony Hart
by gaz_powell » Sat Dec 29, 2018 10:21 am
First one I did I used a kit from SR that had nylocs, so just continued with the belt and braces approach
by Lammyrider » Sun Dec 30, 2018 10:22 am
Welded for belt and braces
Lammyrider
by Tony Hart » Sun Dec 30, 2018 12:45 pm
Flywheel sorted. Just waiting for a replacement mag housing as I damaged it getting bearing out! All I wanted was the seal retainer
Tony Hart
