series 2 150cc oil in exhaust
Postby pg42 » Sun Nov 25, 2018 6:41 pm
More problems with this "rebuilt" project engine. Started it up after loads of work on clutch and gearbox it smelt of burning oil and was smokey which you would expect from an engine that has sat since gawd knows when. It ran for a short time then stalled. i noticed spots of oil on the ground under the exhaust/silencer joint. The engine tried to restart but wouldn't fire up. Pulled off the silencer and a qty of oil ran out of the exhaust manifold. This suggests crankshaft seals (?). There is no dish on the gearbox side casing for an oil thrower so i guess the series 2 didnt have one (?). Any pointers please?
pg42
Re: series 2 150cc oil in exhaust
Postby Knowledge » Sun Nov 25, 2018 9:52 pm
Whilst series one engines did not have dished oil throwers, there is some evidence that a few series two engines were sans oil throwers.
You are probably right about the oil seals. Any engine that has stood for that long must risk seal failure.
A couple of questions. When it was running, was the smoke very white? What is the plug like?
Postby Dimitrios_231 » Sun Nov 25, 2018 10:28 pm
Can I fit a dished washer on a series one engine?
the surface there is flat.
Sorry for the off topic
Dimitrios_231
Postby pg42 » Sun Nov 25, 2018 11:00 pm
The engine casing i have looks identical to this photo. I was told it was a series 2.???
pg42
Postby Dimitrios_231 » Sun Nov 25, 2018 11:39 pm
It could be an early S2,mine is S1,
unfortunately,when I was stripping,
I didn't think to test if I could fit an oil thrower washer
Dimitrios_231
Postby pg42 » Mon Nov 26, 2018 8:47 am
What is a sans oil thrower please
pg42
Postby bike grim » Mon Nov 26, 2018 9:06 am
Sans means “without”
Postby pg42 » Mon Nov 26, 2018 9:41 am
cheers.
pg42
Postby Fast n Furious » Mon Nov 26, 2018 2:38 pm
In my experience, the oil thrower makes very little if any any difference at all.
Just make sure the gearbox filler breather is ok.
Postby pg42 » Mon Nov 26, 2018 3:26 pm
Thanks for all replies. I have just dug the crankshaft out and found the gearbox seal carrier screws loose. That would do it then! Think a monkey must have rebuilt this. New seal and gaskets then hopefully, problem sorted.
pg42
Postby Knowledge » Mon Nov 26, 2018 6:45 pm
We like a happy ending.
