Engine running backwards.
Posted:
Sat Nov 17, 2018 5:46 pm
by steveiow
Just started my lynx up . Kicked it over. It ticked over perfectly okay. Had a bit of a surprise when I put it in gear and it went backwards. Quickly put it in neutral whereupon it farted and coughed then went bang. Thought I'd see if it was dead, so kicked over again. Started 1st kick ran the correct way. Rode it for about 5 miles stopping and restarting. With no problems. Any ideas why it happened?
Re: Engine running backwards.
Posted:
Sat Nov 17, 2018 6:19 pm
by HxPaul
Check your timing,(preferably with a strobe)I once had a series 2 that ran backwards...........my timing was miles out.
Posted:
Sat Nov 17, 2018 7:59 pm
by steveiow
Thanks Paul will do. Was a bit unerving going backwards
Posted:
Sat Nov 17, 2018 9:20 pm
by Dazts1
This will be to do with your timing. My race bike quite often does this. As you say it can be unnerving. Especially sat on a start line of egar race scooters.
My timing is set very close to top dead centre which moves (advance retard ignition) once the motors working. If I let it drop below 3.5 revs on the line you can pretty much guarantee it will go backwards once I set away.
Timing is what I’d be looking at.
Posted:
Sat Nov 17, 2018 10:59 pm
by steveiow
Thanks , tomorrow will be spent checking it.
Posted:
Mon Nov 19, 2018 9:51 am
by grandpa
Hi steveiow
The Messerschmitt bubble car had two sets of points one set was arranged to be advanced(I think) so that when selected the engine would run backwards.This provided reverse. In theory this meant you could have 4 reverse gears.Scary
Good luck in fixing your machine
Grandpa
Posted:
Mon Nov 19, 2018 6:09 pm
by Fast n Furious
I have a programmable ignition kit on one of mine and used to use it for party trick demonstrations in the club car park.
Very unnerving is trying to ride a Lammy backwards.
Nearly dropped it a couple of times.
Posted:
Mon Nov 19, 2018 6:37 pm
by St George
Back to 1970 we drove a bubble car backwards using all four gears, bloody mad in those days.
