Side panel rubber strips
Postby Knowledge » Tue Oct 23, 2018 7:57 pm
The long rubbers on my GP frame that protect the seat arch from damage from the panels are not doing their job. There is damage to the paintwork on the frame seat arch, and I think the reason is that the rubbers don’t go far enough up the frame. When the panels are on, you can barely see the rubbers.
Sorry, this is hard to explain, but the rubbers aren’t really wide enough.
Does anyone sell wider rubbers?
Re: Side panel rubber strips
Postby gizmo » Tue Oct 23, 2018 9:52 pm
The widest ones I have come across are the indian ones and seem thicker. Scooterrestorations have them
gizmo
Postby stephena » Tue Oct 23, 2018 10:13 pm
Recently had some from scooter restorations they are wider than the ones that I had on my li before and can clearly be seen above the side panels. Good fit and side panels are only slightly tighter to get on which I would expect from new rubber.
stephena
Postby Knowledge » Tue Oct 23, 2018 10:14 pm
Thanks guys. Nice to get two identical recommendations.
Martin
Postby ToBoldlyGo » Wed Oct 24, 2018 3:32 pm
ScootRS used to do some nice deep ones. I'm using Scootopia ones on a couple of my scooters at the moment, and they seem pretty good.
Postby Knowledge » Wed Oct 24, 2018 4:18 pm
I think mine came from Scootopia, but your rubbers and my rubbers might be a different batch/supplier.
Postby Wack » Wed Oct 24, 2018 7:34 pm
I always use the Indian ones from Resto's as they are wider and more plastic than rubber so grip and stay on without the need to glue.
Postby Fast n Furious » Thu Oct 25, 2018 12:19 am
Wack wrote:I always use the Indian ones from Resto's as they are wider and more plastic than rubber so grip and stay on without the need to glue.
+1
Postby burnside » Thu Oct 25, 2018 6:02 pm
I bought a set from CamLam that if anything were too wide as they were visible above the side panels
burnside
