Damper Bolt On Kits
PostPosted: Fri Aug 22, 2014 12:24 pm
by Nudger
Has anyone fitted these that can offer an opinion: are they worth using - do they really make a difference?
I've got a standard Li150 Special & am thinking about adding dampers to help improve handling & braking etc...
Any comment gratefully received.
Re: Damper Bolt On Kits
PostPosted: Fri Aug 22, 2014 1:48 pm
by Scooter Paul
Fitting dampers is worth it. Using welded on upper brackets is best but providing you can get the clamp on type to fit properly no reason why not. Clamp on kits were available long before the Indians fitted them as standard.
Paul.
PostPosted: Fri Aug 22, 2014 3:58 pm
by Nudger
Thanks for the quick reply Paul - I was wondering if the clamps would be a bugger to fit properly.
Guess I might as well do it properly & weld the brackets on.
PostPosted: Fri Aug 22, 2014 4:37 pm
by IaninDorset
I remember my mate had terrible trouble with clamp on types back when they were new, he tried everything from wedging, araldite (the stories that could be told of Araldite), I think he had a local firm drill and tap a couple threads and he put some studs in but they didn't last well and he gave up in the end. One of the wacky things I do remember was he tried converting a motorbike fork brace clamp but the thing would shift on a pothole and pull him into a ditch.
PostPosted: Fri Aug 22, 2014 5:19 pm
by Nudger
Hmm not the handling I'm looking for Ian!
PostPosted: Fri Aug 22, 2014 5:48 pm
by IaninDorset
Nor him I think but then he was the bodge artist of them all, he turned his metal lunchbox into an exhaust box rather than buy one for his LD he had lol
PostPosted: Fri Aug 22, 2014 8:39 pm
by bazza3004
Hi ive had the fork clamp brackets on my GP for 2k miles and as yet they havent moved at all.
PostPosted: Fri Aug 22, 2014 9:53 pm
by Revvers
I had bolt on brackets, and now I have weld ons and I don't notice any difference between the two. Dampers are definitely worth fitting imho
PostPosted: Sat Aug 23, 2014 6:21 am
by lammydave
the LTH billet ones are the only ones to get... german engineering and quality
http://www.lambretta-teile.de/Front-sho ... -Lambretta
PostPosted: Mon Aug 25, 2014 5:05 pm
by Custard
I had a pair of the LTH brackets one of them snapped after about 12 months possibly due to aluminium they are made out of being less flexible than steel.
PostPosted: Tue Aug 26, 2014 12:15 pm
by Nudger
Thanks for the replies - much appreciated....
PostPosted: Tue Aug 26, 2014 1:58 pm
by terryj
i have the welded on tops with bolt on bottoms i find that my wheel axle nuts to links need to be re tightened on a regular (almost every rally) basis
