TS1 225 or 240
TS1 225 or 240
Postby Freight10 » Thu Sep 20, 2018 11:47 am
Hi All,
Can anybody tell me how to work out if my ts1 is a 240 which is what I brought it as or if it's a 225.
I've just taken it apart and changing to a mugello but I really want to know what it is...
Thanks in advance.
Freight10
Re: TS1 225 or 240
Postby dscscotty » Thu Sep 20, 2018 12:03 pm
You'll need to find out the stroke of the crank, presuming its a 6omm stroke x 70mm bore that gives you 230cc,
58x70mm=223cc
60x71=237cc
Re: TS1 225 or 240
Postby Freight10 » Thu Sep 20, 2018 12:10 pm
Thanks for the prompt reply....
Freight10
Re: TS1 225 or 240
Postby Sticky » Thu Sep 20, 2018 1:41 pm
It could also be a bored barrel or an even longer stroke crank (e.g. 62mm). It is quite common to 'round up' capacity, even amongst manufacturers (e.g. Vespa GTS300 = 278cc)
You need to take the head off, measure the bore diameter with verniers and measure the distance moved by the piston in mm (stroke) and use a calculator such as http://performancetrends.com/Calculators/Engine-Displacement/Engine-Displacement.php
My guessing is it's most likely a TS1 with a 60mm stroke crank and the capacity (230.91cc) has been rounded-up to the next whole number which is pretty routine and nothing to be concerned about. I expect the seller has an 8-inch cock as well, or at least that's what he tells the ladies...
Sticky
Re: TS1 225 or 240
Postby Rich Oswald » Thu Sep 20, 2018 2:18 pm
Sticky wrote:It could also be a bored barrel or an even longer stroke crank (e.g. 62mm). It is quite common to 'round up' capacity, even amongst manufacturers (e.g. Vespa GTS300 = 278cc)
:lol: :lol: :lol:
Re: TS1 225 or 240
Postby Freight10 » Mon Sep 24, 2018 8:04 pm
:lol: :lol:
Thanks Sticky...
Freight10
Re: TS1 225 or 240
Postby Bofs » Wed Sep 26, 2018 12:24 pm
Does it have a packer plate? If not more than likely a standard 225.
Bofs
Re: TS1 225 or 240
Postby rossclark » Wed Sep 26, 2018 8:47 pm
It could still be a standard 225 even if it has a packer. You still need a 3mm packer if you have a 110 rod on a 57 stroke.
Users browsing this forum: No registered users and 95 guests
