by kennystag » Thu Aug 30, 2018 6:24 pm
mvm tf 75w 80 any good for the li gearbox.
Stag
kennystag
by gaz_powell » Fri Aug 31, 2018 7:45 am
Why deviate from the lambretta spec of ST90 unless you've got some fancy clutch plate compound. It's tried and tested
by kennystag » Fri Aug 31, 2018 8:02 am
Who's deviating, I was just wondering if it would do the same job.
Stag
kennystag
by gaz_powell » Sat Sep 01, 2018 7:52 am
It appears wrong of me to have assumed that it was you considering deviating from the traditional lambretta specification, given you took the time to post the question, so please accept my apology (note to self never assume when responding to a post)
Let's hope someone can help "anyone" who is considering using the 75w80 in a lambretta gearbox.
Gaz
by kennystag » Sun Sep 02, 2018 7:27 pm
Hi Gaz,
Thanks for getting back to me mate. It did sound as if I was going to use it. I found a litre of the oil in my shed and thought it may be of use in my. lammys if I ever needed it.
Sag
kennystag
by gaz_powell » Tue Sep 04, 2018 2:43 pm
In a standard set up I`d steer clear and stick with straight ST90
by kennystag » Tue Sep 04, 2018 4:03 pm
I know the best oil to use, sorry but I am sworn to secrecy.
Stag
kennystag
