Kickstart piston not engaging
I have a problem on a TV175 which I have not experienced before.
When kicking the scooter over, the kickstart piston does not engage with the gear teeth in one place.
It engages for about 5 kicks, but then the kickstart lever goes down without engagement, it might just catch but when pressure is applied it slips. If I carry on pressing the lever down it will eventually catch enough to turn the engine over until it's working fine again. Carry on kicking and it seems to reach the same spot and it happens again.
A GP side cover is fitted to this engine but it has been tapped M6 to accept a Series 3 ramp. It has a modified GP end plate too, the ramp has been removed.
I thought I'd sorted out this problem a month or so ago when I replaced the Li kickstart shaft, which was fitted, with a GP one. I transferred the piston etc to the new shaft. The piston pin was rubbing on the casting so I ground the pin down to clear.
I've taken the side cover off, the piston moves freely. I've inspected the gear teeth on the side of fourth gear; they are perfect. I've replaced the old piston with a new one.
It's as if something is stopping the piston from moving all the way out in one place per revolution of fourth gear. I've ground the kickstart shaft slot a couple of millimetres longer to ensure that the piston goes out far enough, but it made no difference.
I'm going to make up another side cover, the correct one for the scooter and see if that solves the problem.
If anyone can help with this it would be much appreciated.
Denis
Denis
