Series 1
Series 1
Postby betty2015 » Wed Jul 18, 2018 3:30 pm
Thoughts please
Just built series one engine and found on plug shop that plug was black
Also by error kicked scooter off with out choke
I think main oil seal has blown
Ive checked choke works fine
Any thoughts before i pull it apart
New viton seal
betty2015
Re: Series 1
Postby ULC Soulagent » Wed Jul 18, 2018 3:44 pm
What carb and settings would be a good starting point ;)
Re: Series 1
Postby betty2015 » Wed Jul 18, 2018 4:00 pm
Standard carb 175 top end
106 main jet running through original filter
betty2015
Re: Series 1
Postby ULC Soulagent » Wed Jul 18, 2018 5:09 pm
What was the throttle position on the plug chop ?
Was there much white smoke coming from exhaust?
Re: Series 1
Postby gp200ts1 » Wed Jul 18, 2018 6:13 pm
Does the gearbox oil smell of petrol
gp200ts1
Re: Series 1
Postby betty2015 » Wed Jul 18, 2018 8:26 pm
I would say not that smoky but there is a bit
Oil doesnt smell of petrol
betty2015
Re: Series 1
Postby ULC Soulagent » Wed Jul 18, 2018 8:32 pm
Grade of plug?
Wouldn’t think it would be main seal has gone.
Re: Series 1
Postby betty2015 » Wed Jul 18, 2018 9:02 pm
Never started lambretta with out choke ? Cold
betty2015
Re: Series 1
Postby ULC Soulagent » Wed Jul 18, 2018 10:18 pm
betty2015 wrote:Never started lambretta with out choke ? Cold
Miracles never cease too amaze from Lambretta engines :D
Cold !!! What spark plug you using?
And when you say plug was black ! Sooty or oily ?
What actual carb you using?
Sorry for all the questions but every little answer helps us too help you ;)
Re: Series 1
Postby betty2015 » Wed Jul 18, 2018 10:30 pm
Black oily ang nc3 plug
betty2015
Re: Series 1
Standard 19mm
betty2015
Re: Series 1
Postby ULC Soulagent » Thu Jul 19, 2018 8:00 am
betty2015 wrote:Standard 19mm
Standard main jet for this carb is 95.
Try coming down a few points on it.
Re: Series 1
Postby ULC Soulagent » Thu Jul 19, 2018 9:32 am
betty2015 wrote:Black oily ang nc3 plug
Change the plug to an champion n5 or NGK B7es for dialling in a fresh rebuilt engine and take it from there
Re: Series 1
Postby betty2015 » Thu Jul 19, 2018 10:26 am
betty2015
