lam1962brettagg wrote:hi Paul
thanks for info. i've got an iwis in it that was in the previous casing. seemed a little tight when i changed all the parts over to the 'newish' casing from the old one but didn't have this problem before. i have standard chain guides and am presumming i cant slacken the chain anyway can I?
cheers for any further input
lam1962brettagg wrote:Hi Paul thanks for your post from what I can remember I bought a brand new 81 link Iwis chain couple of years ago the rear sprocket and front sprocket are the same from when I bought the Li nearly 20 years ago and have had no problems up until now. (since all engine parts put into a newish casing of similar age) had new bearings/seals/piston rebore and new race layshaft from MB
hope that helps
47 rear and 15 front with an iwis 80 chain.
this is what i had in previous casing and no probs.
