Christmas tree/mainshaft inner bearing track replacement
Postby AlG » Sun Jun 24, 2018 9:37 am
I am building up a tuned engine with new bearings. I am considering replacing the inner track for the christmas tree that sits in the back of the case. Anyone know what measurements I should take to decide if it actually needs doing? And then how to actually extract the track? The old Lambretta workshop guide recommends an extractor tool 59350. Anyone done this?
AlG
AlG
Re: Christmas tree/mainshaft inner bearing track replacement
Postby HxPaul » Sun Jun 24, 2018 10:14 am
First make sure that the bearing surface of the cluster is not worn in any way.Then fit a new bearing into the race in the case (fit it dry)Insert the cluster and see if you have any side to side play,if not its ok to use,if there is play your race needs replacing using the tool and heat,or a bar the correct diameter and lots of grease.
Postby steve t » Sun Jun 24, 2018 2:46 pm
May as well change it if you've got engine in bits might regret not doing it later
steve t
Postby Fast n Furious » Mon Jun 25, 2018 8:17 am
Measuring the wear in this outer track is difficult to do without the proper gauges.
Usual rules apply........ When replacing a bearing, replace it all. If there is any wear in the bearing surface of the mainshaft then these can be reclaimed by specialist suppliers like MB.
Be wary about bearing outer tracks that are made in godknowswheristan, as these can be out of tolerance from the off.
When using the drift and grease method to remove the track, be sure to have the casing properly supported under the track so you don't punch through the casing.
Sticky's manual offers basic advise on how to do this.
Postby AlG » Mon Jun 25, 2018 11:06 am
Many thanks all. I will compare against a few combinations of cases, mainshafts and bearings to decide if it is worth doing. Scootopia does a kit that makes it cheap enough to invest in and be sure of the quality.
Al
AlG
Postby holty » Thu Jun 28, 2018 9:48 pm
last one of these i changed, i found an old lambretta big end pin from an af race crank, welded up the hole in the middle and filled the track with grease and used the big end pin as a drift, hitting it with a hammer soon removed the track, not as hard to do as i expected.
holty
Postby steve t » Thu Jun 28, 2018 10:24 pm
I used a 16mm 3/8 socket and extension I put the extension into the wrong end of the socket filled the race with grease and tapped the old race out using the hydraulic force of the grease ( it's an old fitters trick I was shown as an apprentice) anything round and a good fit will do it as mentioned by holty
steve t
Postby dscscotty » Thu Jun 28, 2018 10:51 pm
The track is 22mm so as mentioned a solid 22mm crank pin is ideal, however my preferred method is to use bread in the track instead of grease!
Postby rossclark » Thu Jun 28, 2018 10:56 pm
dscscotty wrote:The track is 22mm so as mentioned a solid 22mm crank pin is ideal, however my preferred method is to use bread in the track instead of grease!
Pan or Plain?
Postby steve t » Fri Jun 29, 2018 8:01 am
Brown or white :lol:
steve t
Postby Fast n Furious » Fri Jun 29, 2018 6:38 pm
Just make sure its wholemeal. It'll keep regular then.
Postby dscscotty » Fri Jun 29, 2018 8:56 pm
