Warkton Tornado No.1 wrote:If the noise disappears with clutch pulled in & gears engaged, then the problem is most likely within the gearbox area.
My suspicions would be:
something is catching on the first gear or the inner clutch top plate (typically the kickstart) or;
the gears are noisy through too much clearance, a mismatch of gears or a broken tooth/teeth.
Strip down seems inevitable & I would suggest that you have a new, really thick chain case gasket & a selection of gearbox shims to hand as that may be all that it takes to cure it.
harps2 wrote:Warkton Tornado No.1 wrote:If the noise disappears with clutch pulled in & gears engaged, then the problem is most likely within the gearbox area.
Hi As you suspected - checked gear shim clearance and its 0.8mm when I believe max should only be 0.3mm so i guess this is moving and catching kickstart shaft ? - does that sound likely to you and I guess gears stop spinning when you pull clutch and select gear? - do i need to take engine out or can it be done insitu ?
Alan
Warkton Tornado No.1 wrote:harps2 wrote:Warkton Tornado No.1 wrote:If the noise disappears with clutch pulled in & gears engaged, then the problem is most likely within the gearbox area.
Alan
The excess running clearance of the gears on the lay-shaft wouldn't be enough in itself to cause them to rub on anything that they shouldn't.
The clearance to aim for is actually only 0.003" (three thousands of an inch) & it really is worth the effort to get close to that, but definitely no less.
(I keep about two dozen various shims engraved with their sizes & kept in size order so that it makes the process of checking a little less hassle)
You can check clearance with the engine in situ, but I always remove the cluster ("Christmas tree") whilst checking nowadays as it's easier to remove the end plate on & off, then on & off & repeat (Yawn!) until the best shimming is obtained. In other words, the check is only of the loose gears & the cluster being in place is a hindrance whilst that is carried out.
(Do try & obtain 'proper' M7 hardened nuts & spring-washers if you can. Mind you, I don't know who sells them these days)
Once achieved, the cluster with gears can be refitted & that may be enough to quieten down the gearbox.
You will, of course, have checked there hasn't been anything rubbing (shiny internal kick start lever face/swarf in oil) on the clutch top pressure plate, which is such a common problem if the ones I've seen in my lifetime are anything to go by! It's very rare to strip an engine & find one that hasn't rubbed.
I hope that I have helped & not confused you
al pushpak wrote:Hi, I believe (& I'm sure others will correct me if I'm wrong) but with engine running & obviously the scooter in neutral, once the clutch lever is pulled in this pushes the clutch arm shaft on the chain case which in turn pushes down on the clutch bell which engages & "catches" the clutch spider, the clutch spider is bolted to the gear cluster,so as this action takes place it stops the cluster from turning & the loose cogs as they are meshed together as one unit,all that remains spinning then is the crown wheel as it's still free to run & is still being pulled round by the front sprocket which links the two via the chain as the engine ticks over. I have tried to explain it as best I can & I believe how it all roughly works
& I hope you can follow what I've written
but I'm sure an adult will be along shortly to explain it properly
al pushpak wrote:Hi, no probs, now I've read it back it was a little long windedbasically the job of the clutch is similar to that of a brake, to stop things moving, in a lambretta engine (& most other engines) the clutch stops the gear cluster & loose cogs from spinning, this will happen whether a gear is selected or not whenever the clutch is pulled in, it "neutralises the gears" ie stops them moving/spinning, so basically if I'm correct
the gear cogs are spinning until the clutch is engaged, hope that explains it a bit better
coaster wrote:I think with the clutch pulled, the only tings rotating would be the chain and front and rear sprocket (clutch basket) all else should be stationary. However, when you select a gear, there will be some load on the chain as there is bound to be some drag via the clutch. That could cause some noise as the chain tightens and rubs on the tensioners.....just beer induced hypotosizing
Sticky wrote:The whole gearbox stops spinning when you pull the clutch in (if the clutch is working correctly) so it's most likely either the kickstart piston teeth on 1st or the gear selector slightly kissing 1st or 2nd while in neutral.
If you have a GP ramp and it's the kickstart teeth then AF Rayspeed have a solution in a larger diameter pin for the kickstart piston which will pull the teeth back another 0.5mm (but try shimming your kickstart shaft again first).
If it's the gear selector then you'll most likely hear the same noise pushing the scooter along with the engine off in neutral. If it clicks like that then something is wrong in the gearbox and it needs dealing with.
Users browsing this forum: No registered users and 95 guests
