by LammyS3-1991 » Sun Jun 17, 2018 4:09 pm
Hi
Just looking for a bit of advice I have an original genuine S3 horn fitted to my Li S3 it’s been working absolutely fine but all of sudden it’s been sounding every time I accelerate without me even touching it ( & no buttons are stuck etc )
Can someone please give me some advice
Many thanks
LammyS3-1991
by rossclark » Sun Jun 17, 2018 4:35 pm
The horn button usually makes the circuit to earth so the horn sounds.
You've either got a frayed wire or the switch is shorting at the back.
by LammyS3-1991 » Mon Jun 18, 2018 6:16 pm
Thanks Ross I will do some investigation
LammyS3-1991
by a.lo » Tue Jun 19, 2018 4:53 pm
if it is when you accelerate I would suspect the throttle pulley is making contact with some headset wiring, may have rubbed through the insulation.
a.lo
