Starts but doesn't keep running
Postby Norfolk » Sat Jun 02, 2018 6:58 pm
Hi,
Looking for guidance please, scooter has been running perfectly fine this year until the other day, engine will start but only runs for a few seconds before it stops with all the symptoms of running out of fuel, carb has been stripped and jets cleaned several times to no avail. Spark plug is always wet after attempt of starting.
Checking for spark, if normal kick start there is no spark, put scooter on block to increase kickstart travel and a spark is evident although not very strong.
Would I be correct in suspecting the CDI unit of the Varitronic ignition system.
Thanks in advance for any guidance.
Norfolk
Norfolk
Re: Starts but doesn't keep running
Postby CHRIS in MARGATE » Sat Jun 02, 2018 10:29 pm
You can buy a very cheap CDI online. It will prove the problem one way or the other. If that's not the problem them you have a cheap "get you home" spare. Under £11 delivered. They work fine.
Probably then it's the LT Coil on the stator.
Postby Norfolk » Sun Jun 03, 2018 9:40 pm
Thanks Chris for your suggestion
Norfolk
Postby NorthernJordan » Mon Jun 04, 2018 8:24 am
I thought Variatronic ignition systems ran a different CDi. I'd be surprised if you can pick one up for a £11?
NorthernJordan
Postby Storkfoot » Mon Jun 04, 2018 11:51 am
Have you checked for an air leak?
Postby Norfolk » Tue Jun 05, 2018 9:44 pm
Hi,
Having trouble discovering which CDI unit I need, any suggestions would be appreciated
Thanks in advance.
Norfolk
Postby rossclark » Wed Jun 06, 2018 1:48 pm
Best bet would b to contact CAMLAM to see what they recommend for the Variotronic
Users browsing this forum: No registered users and 93 guests
