by Cortez the killer » Wed May 16, 2018 11:26 am
Third hand tool for setting up cables...any good ??
Always found setting cables up a bit fiddly (particularly on my Mrs primavera, but that's another story) so anything that helps would be good.
Cortez the killer
by bike grim » Wed May 16, 2018 1:18 pm
On a Primavera, yes useful. Not really necessary on Lambretta in my view.
by Solid Air » Wed May 16, 2018 1:19 pm
I've found it to be a really handy tool for the clutch cable, worth getting.
Mark
by coaster » Wed May 16, 2018 2:16 pm
Solid Air wrote:I've found it to be a really handy tool for the clutch cable, worth getting.
Mark
That's the one I usually struggle with, who sells those tools?
by Cortez the killer » Wed May 16, 2018 2:36 pm
Allstyles do them for around £13, seen better quality ones on Google for about £23..in a related topic, I`m amazed that no one has re-designed the whole trunnion system as even with good access they`re still a pain in the arse to get two spanners in to tighten, there must be a better way ??
Cortez the killer
by HxPaul » Wed May 16, 2018 3:18 pm
If its a cable puller,they seem a bit pointless to me.
by coaster » Wed May 16, 2018 4:05 pm
Cortez the killer wrote:Allstyles do them for around £13, seen better quality ones on Google for about £23..in a related topic, I`m amazed that no one has re-designed the whole trunnion system as even with good access they`re still a pain in the arse to get two spanners in to tighten, there must be a better way ??
Thanks for that, I'll take a look. Jaimie (Superiebar) form Barcelona does a brass version with a 13mm square head on the barrel which is very easy to hold with an open ended spanner whilst you tighten the allen key.
by bike grim » Wed May 16, 2018 5:02 pm
coaster wrote:Cortez the killer wrote:Allstyles do them for around £13, seen better quality ones on Google for about £23..in a related topic, I`m amazed that no one has re-designed the whole trunnion system as even with good access they`re still a pain in the arse to get two spanners in to tighten, there must be a better way ??
+1 the “Straight Jacket” (that Jaime has named it) is a very good idea and I have them on 2 of mine.
by dickie » Wed May 16, 2018 6:16 pm
Cortez the killer wrote: I`m amazed that no one has re-designed the whole trunnion system as even with good access they`re still a pain in the arse to get two spanners in to tighten, there must be a better way ??
They have.....geordie dickie engineering services sell a short 10mm and 11mm open-ended spanner for only £20 plus postage. It's an absolute bargain.
by Solid Air » Wed May 16, 2018 6:17 pm
coaster wrote:Solid Air wrote:I've found it to be a really handy tool for the clutch cable, worth getting.
Mark
Had mine sometime, really helps in taking up the clutch cable tension and holding there. eBay have loads, this one is very similar to mine...
Users browsing this forum: Baidu [Spider] and 73 guests
