Imola 186 inlet manifold split
Postby Norrie Bodge » Tue May 15, 2018 3:31 pm
Lads
A mate has an imola 186 kit that’s done approx
350 Miles since built & the rubber has split!!
Which is fine?
But on stripping it off for him, the rubber/manifold
Is all one piece?? Has anyone had this issue ?
& has a way of fixing this ?
Norrie Bodge
Re: Imola 186 inlet manifold split
Postby HxPaul » Tue May 15, 2018 3:45 pm
Postby soullad » Tue May 15, 2018 3:58 pm
What carb size is it for, a 28 / 30 mm dellorto phb type carb
Would the newer type inlet manifolds with a bolt on rubber flange not work?
soullad
Postby St George » Tue May 15, 2018 5:10 pm
I have one of those in a box of spares, the rubber pushes on and locks on a ridge, the carb does the same. It came with my 30 mm Oko.
St George
Postby gaz_powell » Tue May 15, 2018 5:34 pm
Cut the rubber off and use hose???
Postby Norrie Bodge » Tue May 15, 2018 5:42 pm
St George wrote:I have one of those in a box of spares, the rubber pushes on and locks on a ridge, the carb does the same. It came with my 30 mm Oko.
Pm sent m8
Norrie Bodge
Postby Norrie Bodge » Tue May 15, 2018 6:28 pm
soullad wrote:What carb size is it for, a 28 / 30 mm dellorto phb type carb
It’s for a 28mm PHBH m8
Yes they the better option but at £100+
He’s a bit miffed that it looks like the one he has can’t just be replaced ?
He’s on cutting the rubber off now
I will post up later how the manifold looks when off
Norrie Bodge
Postby Norrie Bodge » Tue May 15, 2018 6:33 pm
Norrie Bodge
Postby soullad » Wed May 16, 2018 4:58 pm
I might have an unused 28/ 30 mm inlet with spare flange, will check mate
soullad
Postby Norrie Bodge » Wed May 16, 2018 9:35 pm
Cheers soullad appreciate you looking m8
Pm me if any joy plz
Norrie Bodge
Postby Norrie Bodge » Sat Jun 30, 2018 11:11 am
We got sorted with a used manifold
but to the heck could we get me mates bike to run/start ok
So the Other version of imola manifold was not compatible
So along with user - special brew... we decided on a bit of surgery to orig manifold
We manage to source a piece of billet 12mm alloy plate from a good m8
& here the pics on what we managed to get this sorted
Chopped off the lip where carb rubber lived
Marked out ready
All cut & dressed up & prepped
Back from the welder (special brew)
Dremel/rotary - cleaned up & m8 holes tapped out
All Fitted & yep she lives again
Norrie Bodge
Postby shane BBoys » Sat Jun 30, 2018 12:29 pm
Nice work .
Cheers Shane
shane BBoys
Postby Knowledge » Sun Jul 01, 2018 12:07 pm
Well done NB. That was exactly what I was going to suggest, and then I scrolled down to see you had already done it. It looks better than new.
I hope you found the experience rewarding.
Martin
