Stevepshipley wrote:well, not really sure. Indian flywheel I assume and not sure of stator origin. but why would "static move?
Adam_Winstone wrote:Static timing can even advance with revs (!) but this is rare and normally due to misalignment of the pickup and triggers on flywheel. I had this recently and I was shocked how much the static (meant to be) timing could wander. Not an issue if it retards a few degrees with revs but not good when it advances as it'll cause the motor to run hotter.
Fast n Furious wrote:Also having too big a plug gap won't help.
As won't using a resistive plug with a resistive plug cap.
Users browsing this forum: Baidu [Spider] and 56 guests
