Paul_from_Thornbury wrote:Perhaps it's an issue with retard boxes and external pick ups with DC set ups, I'll ask Anthony. It would be a surprise as his CDI's are DC.
CHRIS in MARGATE wrote:Why when the pick up is replicated externally using the same circuit will it not work with an Augusto?
NorthernJordan wrote:When I fitted mine I was told it would work with an M-Tech, however it would not rev cleanly.
The plan was for this to act as a back rather than the main ignition so I was not too fussed.
I believe there was a small amount of retard built into them, circa 3 degrees? Though I couldn't see much evidence of that when strobing...
However, like I say it's a back up and gives piece of mind for your ignition system.
HxPaul wrote:I've got an Anthony Tambs external pick-up on one scooter.If I run the external pick-up off the lighting coils with my lukas CDI,it runs great,but I cant turn it off with the igntion switch,whereas if I use the internal pick-up on the stator plate it will.I have no idea why.
Users browsing this forum: Baidu [Spider] and 73 guests
