LI 150 Special - Brake light OK but no running light - HELP
Re: LI 150 Special - Brake light OK but no running light - H
Postby CHRIS in MARGATE » Mon Apr 03, 2017 8:45 pm
I'll be looking out.
Postby harps2 » Tue Apr 04, 2017 10:30 am
CHRIS in MARGATE wrote:I'll be looking out.
hi Chris
Weird - with meter set on 200 i get reading of 20 on one of the bulbs i have or 1.2 on other bulb - both the same type of bulb?
- surprised? - no reading when bulb out (meter stays on 1 at left side) -what next
harps2
Postby CHRIS in MARGATE » Tue Apr 04, 2017 5:15 pm
1.2 ohms is wrong.
20 ohms is correct
Use I=V/R
1.2 ohms equates to 120 watt bulb.
20 ohms equates to 7 watt bulb.
That 1.2 ohms is able to take the lot and short your headlamp supply to earth through its filament.
I'm just going to find one to measure.
Might end up with egg all over my face.!!
Postby harps2 » Tue Apr 04, 2017 5:18 pm
CHRIS in MARGATE wrote:1.2 ohms is wrong.
20 ohms is correct
Use I=V/R
OK I am here awaiting your reply
harps2
Postby CHRIS in MARGATE » Tue Apr 04, 2017 5:36 pm
Spare bulb I have is 5.8 ohms and it's a 25 watt bulb.
Can you pull the black and swap it with the wire feeding the brake light filament. I wonder if that might make a difference.
Are you on Facebook "Lambretta Tuning" Ask for Anthony Tambs.
Postby harps2 » Tue Apr 04, 2017 5:40 pm
CHRIS in MARGATE wrote:Spare bulb I have is 5.8 ohms and it's a 25 watt bulb.
see previous message
if i wire up to charger the thinner longer filament is the running light and the brake light the shorter fatter filment - headlamp works OK but dimms when brake light applied as you would imagine.If using scooter loom wiring connected (engine running) I have to change the connectors in rear light to get them to work and this time shorter fatter filament is running light and longer thinner filament is brake light
harps2
