Adam_Winstone wrote:A pal had similar when he assembled and put the needle through the retaining plate, rather than underneath it, allowing the needle to move independently of the slide.
I had a quick skim read and see that you've swapped out various bits of the ignition system but have you tried it with the loom's green off the CDI, so bypassing any failure of ign switch, loom earthing, etc?
To me it does still sound like an ignition issue but could just be carb... the two often feel like each other.
Holed float? Do you have the 200 needle seat and needle to try it with? Changed the fuel out? Blocked exhaust? Fuel pipe being crimped under seated load of rider?
Best of luck.
Feersum Injun wrote:Is your rubber mount ok? No split?
Adam_Winstone wrote:The benefit from the change might give an indication of what lines to follow up, however, the relationship of ignition and carburation still exists; a poor ignition will struggle to burn a rich mix, a change to either will have influence.
Warkton Tornado No.1 wrote:
We're all clutching @ straws for you...
Adam_Winstone wrote:Does the tap flow correctly in both positions? Knowing that you had crap in the tank, has closing the tap off allowed debris to get into the drillings/channels of the carb? If you take the float assembly off and turn the fuel tap on, does it come through at a rate of knots?
dscscotty wrote:Have you done a leak down test?, I'll chuck this into the mix, recently I've seen a few drive side halite washers fail, some of which the gasket had all but disintegrated, some of the scooters, had mis -fires, difficult or unable to start, it was a swine to find, until a leak down picked it up, however it was'nt the problem that I initially thought would cause the symptoms displayed.
Steve D wrote:It sounds like a stator problem. Have you checked the ohms readings. Had a few stators read ok, start ok and breakdown when they start to warm up.
