Road test of a reasonably priced shock
Re: Road test of a reasonably priced shock
Postby Storkfoot » Mon Apr 30, 2018 8:00 pm
ToBoldlyGo wrote:Ouch! The rod is gone altogether. :shock: I wonder how Mr Storkfoot is getting on with his?
I haven’t put enough miles on it yet to make an informed comment. I have been using my other Lammy during the Winter.
This is worrying though, I agree.
Foremanbob, what sort of load have you subjected the rear to?
Postby coaster » Mon Apr 30, 2018 8:32 pm
Storkfoot wrote:.....Foremanbob, what sort of load have you subjected the rear to?
Could be a factor but the majority of the load is going through the spring, is the damper setting adjustable at all?
Postby Storkfoot » Mon Apr 30, 2018 8:47 pm
No, mate. Just the spring tension.
As regards the customer service from Scootopia, I have always found them easy to get hold of on the phone and pretty reasonable overall. I’d definitely call them.
Postby foremanbob » Tue May 01, 2018 1:05 pm
I'm 14st... this has been 137 miles of gentle running in around town and quiet country roads. I have not hit any potholes or ramps etc
foremanbob
Postby ToBoldlyGo » Tue May 01, 2018 2:01 pm
I'm a fan of Scootopia. I've dealt with them a lot, usually in person, and never had a problem. I really would give them a ring and speak to either Lee or Paul, because it's plainly at fault in this case, with its magic disappearing rod. I'm sure they'd be happy to help.
Postby Feersum Injun » Tue May 01, 2018 4:31 pm
I put one on last spring and did SDR, C2C and Derby 150 on it without any issues. It's pretty decent, much better than its escort equivalent.
Feersum Injun
Postby Storkfoot » Tue May 01, 2018 10:14 pm
FB, please let us know what Scootopia say. Good luck.
Postby foremanbob » Wed May 02, 2018 9:59 am
No quibble refund... I actually wanted a replacement, but they only have S2's in stock just now.
Posting it back to them for their review
foremanbob
Postby Storkfoot » Wed May 02, 2018 11:05 am
I’m looking at pics on a phone so it is hard to see. Did the rod sheer off?
Postby foremanbob » Wed May 02, 2018 11:14 am
It has disconnected from the eye at the top of the shock, and retracted into the base of the unit.
Cant see whether this was a shear or a mechanical (circlip type) fail
foremanbob
Postby foremanbob » Mon May 07, 2018 9:32 pm
failure of the pin connection to the top of the shock... sheered
foremanbob
Postby Storkfoot » Mon May 07, 2018 10:37 pm
foremanbob wrote:failure of the pin connection to the top of the shock... sheered
So, are they accepting it may be a flawed design?
Postby dickie » Mon May 07, 2018 11:11 pm
Could just as easily be a manufacturing fault.
Postby ROClarke » Thu May 10, 2018 10:39 am
I have had a rod shear on a cheap shocker, fortunately they tend to go at low speed, mine went going over a lowered kerb off the road into a service station for fuel.
That was a recovery job and a 2 hour wait on a Sunday.
The industry does put out some crap, but surely they have a duty of care on parts that effect safety, if this happened to a new two wheeled vehicle it would be in the press and result in factory recalls.
I am sorry but my life and time is worth more than £70,BGM fitted now.
ROClarke
Postby ToBoldlyGo » Thu May 10, 2018 1:00 pm
I can understand that. But there are cheap shocks that are robust and last forever. I'm sure you can get more expensive shocks that fail as well.
Postby coaster » Thu May 10, 2018 6:53 pm
ROClarke wrote:...............fortunately they tend to go at low speed, mine went going over a lowered kerb off the road into a service station for fuel.
That makes sense when you think about it as it would be unlikely to snap under compression, more likely when it is suddenly extended as in your case it would be dropping off a kerb or over a speed bump etc.
Postby sunrisemac » Thu May 10, 2018 9:40 pm
I agree, I had a similar thing happen a couple of years ago and that went as the scoot went light over a hump in the road. http://www.ilambretta.co.uk/forum/viewtopic.php?f=22&t=6728#p56202
sunrisemac
Postby PSC GP200 » Wed Jun 06, 2018 11:06 pm
I put a standard Scootopia on the back of my GP a year ago, done about 2k miles, some two up and it has lost all its damping action. Like a bouncy castle now. I expected better. :|
PSC GP200
Postby Cgt75b » Sun Jun 10, 2018 8:00 am
I have just bought a second hand Pro Tech series 2 shock. The most I have ever spent on suspension I just hope it's money well spent.
Postby Watfordwhite » Sun Jun 10, 2018 9:31 am
You won't find much wrong with Pro Tech. I have the front and rear on my S2.
Watfordwhite
Users browsing this forum: No registered users and 99 guests
