Warkton Tornado No.1 wrote:Lambretta ownership can be very frustrating...
My knee jerk reaction:
You'll still get a spark even if the condenser is failing.
MK Monty wrote:check the woodruff key a spark at the wrong time is no good. they seem to shear dead easy these days, I never did my flywheel up dead tight when setting timing as I knew it would be off again in a minute, lost a few because of it, easy to find the bugger stuck on the magnate
Wack wrote:Check the terminal from the condenser to the points is not touching the flywheel.
grandpa wrote:Make sure choke is working.or remove bellows and hold a piece a cardboard over carb mouthpiece while you kick her over as a makepiece choke
Grandpa
Wack wrote:To rule it out unplug all the lighting wires from the ign switch and use a piece of wire from the loom brown to touch all the other terminals in turn ie to yellow on hlight bulb holder for pilot, then to black for rear light and the dip and high blue and red. If everything lights up then the switch must be faulty. Also if you're still on the original stator then presumably you're still using the junction box so check that out for continuity and connections.
harps2 wrote:Hi ALL
Can anybody else confirm if its OK to attached a 6V battery charger to Harness loom to check wiring/lighting rather than start engine each time?
MK Monty wrote:Where are you based. I'm sure someone could pop round and have a look for you.
Toddy wrote:harps2 wrote:Hi ALL
I always do it that way to check my system live to Brown feed out loom and well earthed
