Replacing cables
Re: Replacing cables
Postby P D: SC Chester » Sat Dec 17, 2016 6:35 pm
HxPaul wrote:
P D: SC Chester wrote:Ha ha yeah. If you put Lambretta..... into a a search on eBay for example. The prices people charge is to basicly rip scooterists off, amazing!
Ive been looking for a new carb and anything Lammy is pricey, just put in 'carb' and its a totaly different ball game.
Ive just bought a Mikuni carb for........? £17!!!! It may be a fake or a load of crap? But its worth a punt. And i couldnt give to f......s if Mr genuine Itaian thinks its just not the done thing!
If you think lambretta parts are expensive,you want to try buying parts for Harley-Davidson,but at least when you buy something it may be expensive but at least it does the job and it fits.
Carb came today, its a Mikuni copy but really good quality. Fits and works a treat!!!
P D: SC Chester
Postby HxPaul » Sat Dec 17, 2016 7:14 pm
Is it a 2 stroke or 4 stroke carb,have you changed the jets and needle ?
Postby P D: SC Chester » Sat Dec 17, 2016 7:29 pm
Its a 2 stroke, got spare needles.
Only issue is the choke which will need a conversion from pull to cable.
Those lovely Gerries at SIP, have a choke conversion for sale, which was nearly as expensive than the bloody carb!
I will fettle one from old carbs...
P D: SC Chester
Postby HxPaul » Sat Dec 17, 2016 7:34 pm
Good result ! :D
Postby Knowledge » Sun Dec 18, 2016 9:02 am
P D: SC Chester wrote:I will fettle one from old carbs...
Post some photos of your choke conversion; there may be others who could use that information.
Fettle, learn, share.
Postby P D: SC Chester » Sun Dec 18, 2016 1:40 pm
Ok Pal, will do. The choke conversion is the easy bit, getting my pics to load on to this site at the right size, is the challenge :oops:
P D: SC Chester
Postby Norrie Bodge » Sun Dec 18, 2016 2:19 pm
P D: SC Chester wrote:getting my pics to load on to this site at the right size, is the challenge :oops:
use this m8, really easy for adding pics -> https://postimage.org/
Norrie Bodge
Postby P D: SC Chester » Sun Dec 18, 2016 9:42 pm
Cheers Bodge......
Just an update on the choke, I managed to match up the choke to use the cable, but the push button one that is fitted, clicks on and off so nicely, I'm considering using it and attaching a rod similar to the petrol tap/rod and cutting a hole for it next to the petrol tap and simply using the choke that way. Very on off able!
P D: SC Chester
Postby Phil D » Mon Dec 19, 2016 4:09 am
Stand by for the abuse! :D
Phil D
