Re: clutch slip ?
Postby dickie » Thu Jul 14, 2016 9:41 pm
Second loose gear wrong way round and not catching sliding dog properly?
surley (to preload the spring) that would just raise the sprocket assembly if put under the packing washer before the sprocket sleeve,not take up the height of the sprocket to tighten the spring,to do that the packer should go on the sleeve,bombom I think that is right if you think about it,Adam_Winstone wrote:You can look for wear on the front sprocket, which might help to identify the issue. As for curing it, you can change the sprocket (some machined too low) and fit a new sprocket assembly spring, however a good check to see if this is the case is to leave everything as it is but to fit a suitable washer under the sprocket assembly to jack it up and to add more preload to the spring. This may or may not put your sprockets out of alignment, which in turn can lead to chain wear, however, it allows you to test it to see if this is the reason for the feeling of clutch slip.
CamLam sell, or did a while back, shims of various thicknesses as they had found incorrectly machined sprockets to be an all too common problem, however, they were good enough to tip me off to the shim that fits between rear sprocket and endplate bearing being the correct size to do the same job. The shim needs to be fitted between the oil thrower washer and the splined column of the front sprocket assembly.
Post by isthmus » Mon Aug 15, 2016 12:00 pm
