Diablo tank insides
Re: Diablo tank insides
Postby Vmakgp » Tue Jul 12, 2016 9:22 pm
Storkfoot wrote:
Storkfoot wrote:....Edit: Tankcare Products do a petseal remover. I have just ordered some online.....
Just to finish off this thread.
I suspect the issue with the sealant was that when the tank was re-powder coated, it was put in an oven and this started breaking down the sealant. Petrol then started getting at it and bits started breaking off. That's my theory anyway.
The Tankcare petseal remover has worked. It does break down the sealant and gets it to peel away. It is still hard work to get it all out of the tank though but it is done now.
Thanks again for all the ideas.
That's good news then fella , I found a website that had a blog on a old Honda tank that had been pet sealed over the years to the point it didn't hold its stated amount of fuel ,the guy was having problems with the old pet seal as apparently it was breaking down the bowle in the carb being full of a powdery residue the firm cut the tank open and started to brake the old pet seal up no wonder it didn't hold enough fuel the lumps of old seal are over an inch Fick in the pics , he then braised up the tank , before re pet sealing with modern pet seal that doesn't brake down with modern high efinol fuels .
Vmakgp
Postby Storkfoot » Tue Jul 12, 2016 9:42 pm
An inch :o
I'm not planning on sealing it again. It's okay inside as far as I can see although I can't see behind the baffle plate.
I've swilled it out with some Phosphoric Acid and then washed it out with water. Drying now and will do a final wash out with petrol before it goes back on the scoot tomorrow night.
