Let's hear your "get you home bodges" ......
Re: Let's hear your "get you home bodges" ......
Postby Toddy » Thu Oct 01, 2015 12:15 pm
Eden wrote:Ive currently got Zip ties holding my fuel tank in due to broken straps :(
A bodge I did on one of my engines just the other week was to seal an air leak in the crankcase, the leak became apparent when I did an air test after building it back up with a new crank after the old crank big end had let go, I did look around the crankcase to see if the conrod and smashed it anywhere but didn't see any cracks or holes yet the air test revealed a crack. I count be arsed to strip it all back down and get it welded so I just mixed up some chemical metal and spread it over the crack. seems to have held so far lol
I witnessed that the other night :o :lol: :lol: :lol: :lol:
Postby berniek » Sat Oct 03, 2015 1:56 pm
A few years ago on the way to a rally. One of the girls was riding in front of me on the motorway and I noted fluid pissing out of her bike. Thought petrol tank had gone, rode past her and waved her over. Chaincase drain plug had gone and gear oil was lost. No worries we thought, we will have one in our toolboxes, but none available. Thought about using the filler plug, but couldn't block the breather properly to stop oil leaking.
We ended up wrapping electrical tape around the thread of a spark plug to make up the difference between 14 mm and 16 mm thread. Wound it in, filled up with oil, happy days.
berniek
Postby spanner rash » Mon Jan 18, 2016 10:28 pm
Rear wheel nearly fell off yesterday- managed to wobble to a standstill to find a sheared hub stud, another with stripped thread and the remaining two nuts loose and barely hanging on! Luckily had 3 cable ties in tool box which I just managed to thread over the edge of the rim and round the lugs on the hub...
7 mile (very slow!) ride home
spanner rash
Postby Fast n Furious » Thu Mar 30, 2017 6:28 pm
I cringe at the thought of it now as to some of the bodges I carried out as a youth. One of the downsides to being a bit handy is you get the job of getting the rest of your club members home from a rally.
The most common one I remember was the situation where the spark plug thread had stripped and would no longer hold the plug.
Solution:- Hold the plug against the kerb with a pair of pliers and hit the pliers with a brick until the plug ovalates sufficiently to grip whats left of the head threads. No pliers available? No worries...... Just use the brick.
This one got a few lads home. What really annoyed me, with some, was that this bodge would still be in operation up to a month later! :shock:
