Why o Why
Re: Why o Why
Postby Warkton Tornado No.1 » Tue Sep 01, 2015 6:33 pm
Sorry if I confused you & thanks for your helpful reply.
A picture paints a thousand words:
Re: Why o Why
Postby Warkton Tornado No.1 » Tue Sep 01, 2015 6:42 pm
Ooops!
Ross(?)
I've just noticed your clip in the photo is going the wrong way. Although it is unlikely to come off, I would turn it around @ your earliest convenience.
The theory is that the clip is more likely to get pushed back on by anything untoward dragging against the chain, rather than pushed off.
You can see why racers used to carry five different chain lengths with them as even with just from 14 - 19 tooth front sprockets & 46 - 48 clutch rings you have to.
Re: Why o Why
Postby rossclark » Tue Sep 01, 2015 7:11 pm
I did turn it round, thanks, just the only pic I could find of it.
Cheers, Ross
Re: Why o Why
Postby Strummer10 » Sat Apr 01, 2017 2:10 pm
Just searched on here and got this post and wanted some advice.
The 'Lammy bible' says i need an 82 chain with a 19 / 46 sprocket set up.
Dilemma is i have just fitted an AF 46 rear cassette clutch with the 19 tooth sprocket but the 82 chain is proper baggy. I have tried other 82 link and 80 link chains in the garage but the 80 is too tight and the other 82's just as baggy. I think I might need an 81 link, has anyone experience of that set up ?
I could use a tensioner where the chain is pulled down but would prefer the conventional 'push up' green chain guide...
Strummer10
Re: Why o Why
Postby HxPaul » Sat Apr 01, 2017 4:00 pm
Strummer10 wrote: i have just bought a pull down guide i'm not confident it's the right way forward, particularly when the chain passes underneath a nylon black block and between an aluminium square block into the case....ie; if it slackens even more it could end up grating the guide.
Anyone else had this and is there a remedy to keep the conventional 'push up' green chain guide you get as for me the pulling down of the chain makes no sense personally ??
I'm struggling to understand what you mean.................
Re: Why o Why
Postby a.lo » Sat Apr 01, 2017 4:27 pm
some of those genuine iwis are just wrong i ,ve got an 80 link for 15/46 sprockets and the rear one is like your first picture, bought from a reputable dealer with hologram on box. it also has a cambridge lambretta sticker on it, but did not buy it from them.
a.lo
Re: Why o Why
Postby Fast n Furious » Sun Apr 02, 2017 1:20 am
Strummer10 wrote:Just searched on here and got this post and wanted some advice.
I have this setup and I think I took a new 80T chain, Split it, and added a link n a half with a push up tensioner.
Re: Why o Why
Postby Strummer10 » Sun Apr 16, 2017 9:06 am
TBH .....yes I should try an 81 chain that would probably resolve it
Strummer10
Re: Why o Why
Postby betty2015 » Sun Apr 16, 2017 4:26 pm
Hi mate which gearbox are you using i have a 48Icrown wheel and woundeting which gearbox to use thanks
betty2015
Re: Why o Why
Postby Strummer10 » Sun Apr 16, 2017 7:14 pm
Hi i'm using the original GP 200 Italian box to start with and see how I go with it
Strummer10
Re: Why o Why
Postby betty2015 » Sun Apr 16, 2017 7:26 pm
Hi mate me to bud I've tried 48 16 me devtour and was to revy might try the 15 cheers
betty2015
Re: Why o Why
Postby Strummer10 » Sun Apr 16, 2017 7:56 pm
i'm going 19 / 46 with the Italian GP 200 box for a touring set up
Strummer10
Re: Why o Why
Postby Strummer10 » Sun Apr 16, 2017 8:00 pm
just thinking about whether to stick the BGM clubman on or divert to an expansion
Strummer10
Re: Why o Why
Postby betty2015 » Sun Apr 16, 2017 8:19 pm
Exhausts make a difference
betty2015
Re: Why o Why
Postby P D: SC Chester » Mon Apr 17, 2017 3:37 pm
On the subject, ive bought a 16 tooth for a GP 150. I've read that a stretched regular chain should fit and as I think it's possibly 40 years old, does anyone think that it will be sufficiently stretched, or should I be going a half up?
I've got a modern plastic Tensioner.
P D: SC Chester
Re: Why o Why
Postby Adam_Winstone » Mon Apr 17, 2017 5:35 pm
^... No way of knowing until you strip it to try, however, if it is the original chain then I would say 'probably, yes'.
PS - Personally, I hated my standard GP150 when I tried it with a 16 tooth front sprocket as it meant I had to thrash it everywhere and road conditions needed to be right, otherwise I was changing down to 3rd way too much. I hope that your set-up suits it more than mine did.
Re: Why o Why
Postby P D: SC Chester » Mon Apr 17, 2017 7:07 pm
Thanks Adam. Food for thought. I have ported the cylinder and it goes really well compared to what it was. And when you take it to the full in 3rd, there is still a good increase in 4th gear.
So, I might leave well alone.
I've now also gone back to a jetex, which it likes better than the bigger PWK. But still prefers the Sterling to the Clubman exhaust , which I found odd, because when it was totally standard, fitting the sterling meant I didn't really have a 4th despite it liking a bigger carb.
When people say every scooter is different, they weren't joking!
P D: SC Chester
