Tubless rear
Re: Tubless rear
Postby Rich Oswald » Thu Aug 06, 2015 6:47 pm
Fish wrote:
Rich Oswald wrote:
Fish wrote:You will need longer studs on both hubs if using AF tubeless rims, on wide or standard
Not correct for standard width. No stud mods req.
jonoy wrote:Got my rims and tyres today
Supplied with tall dome nuts and 2 different washers
Cannot get the front on not enough thread
Thats why I posted my comment - I had the same issue, change studs to longer and all good
And that's also why I posted mine as I fitted myAF rims on standard studs withe no modifications and the nuts went on fine on both front and rear.
Re: Tubless rear
Postby jonoy » Thu Aug 06, 2015 9:19 pm
Got it done in the end
Put wave washer on, put done nut on tighten it down this pushes the wave washer on
Then take off dome nut put split wash on ang this gave enough thread to tighten down
Should have took my time I've really scratched the polished rim
jonoy
Re: Tubless rear
Postby Storkfoot » Thu Aug 06, 2015 10:19 pm
Surely a wavey washer, spring washer and a nyloc is way overkill :idea:
When I use a nyloc I only use a flat washer although you must remember that you can't keep re-using nylocs forever. I use spring or wavey washers when just using a normal nut.
Anyway, glad you got it sorted in the end.
Re: Tubless rear
Postby jonoy » Fri Aug 07, 2015 2:32 pm
No Nylock
It's a wave washer split washer and deep dome nut
Because of the recess the Dome nut is long so as to get some purchase on it
jonoy
Users browsing this forum: Baidu [Spider] and 85 guests
