paul213 wrote:I notice from your post you check the plug when you get home. this is no good as the plug will be darker due to slow running you need to check the plug at various throttle settings there and then , ride for about a mile on a throttle setting ,release the throttle pull in the clutch and turn off the ignition do not allow engine to idle. coast to a stop remove plug burning fingers put in another plug and repeat at a different throttle setting. I do mine at just below 1/4, just above 1/4, 1/2, 3/4 and just below fully open .if you have a pocket full of plugs you can mark them to indicate which throttle setting it was and have a good look at the colour when you get home its easier than on the side of the road ,then adjust the appropriate jet as necessary.
rossclark wrote:Be careful buying plugs off eBay unless it's a reputable seller, there are fakes out there.
Users browsing this forum: Google [Bot] and 73 guests
