Inboard disc help page..............hopefully
Re: Inboard disc help page..............hopefully
Postby HxPaul » Tue Mar 08, 2016 11:04 am
bendyminge wrote:So glad I read this. I took my ScootRS disc apart for paint and I've been battling with it all night to try and get it back together. The three pins that hold the disc, allow it down about half way and then it just jams. When taking it apart again to retry I have to knock the disc off with some force!
After reading this thread, I'm guessing this is not a new issue and it sounds like I just need to rub down the pins slightly, enough for the disc to drop freely to the bottom of the pins.....is that right?
Ben
Try removing the anti-rattle clip in the disc and see if this allows it move more freely on the pins
Postby Storkfoot » Tue Mar 08, 2016 12:44 pm
Does the ScootRS version have an anti rattle clip?
Postby HxPaul » Tue Mar 08, 2016 2:53 pm
Storkfoot wrote:Does the ScootRS version have an anti rattle clip?
Yes.I have one.
Postby Storkfoot » Tue Mar 08, 2016 9:37 pm
In which case, I wholeheartedly agree :)
Also, put a smear of copper grease on the pins (not too much). Hopefully, ScootRS' manufacturing tolerances have left a reasonable gap for the disc to move freely. Don't worry unduly if you can hear it rattle a bit when walking the scooter, this disappears when your moving.
Postby coaster » Tue Mar 08, 2016 9:46 pm
Where exactly is the anti-rattle clip? I've had my ScootRs one apart several times and haven't notices one :?
Postby Storkfoot » Tue Mar 08, 2016 10:03 pm
http://www.scooterrestorations.com/Imag ... sembly.asp
Item 49, sits in a recess and presses against the pins. This is in a Campagnolo disc set up but not all the replacemet discs available actually have a recess, which is why I posed the original question.
Postby bendyminge » Tue Mar 08, 2016 10:12 pm
Thanks for the replies guys, I'm away with work at the moment so can't check if mine has one or not, but from memory I think it does.......I'll report back.
Ben
bendyminge
Postby coaster » Wed Mar 09, 2016 12:06 am
Storkfoot wrote:http://www.scooterrestorations.com/Images/Sec9a_disc_brake_assembly.asp
Ah gotcha, possitive mine hasn't got one
Postby HxPaul » Wed Mar 09, 2016 9:46 am
If its a scootRS front inboard brake it will have one.
http://scootrs.com/category.cfm?category=84
Postby bjhart » Mon May 30, 2016 11:26 am
I have converted my in board disc to a circlip retained cylinder type semi-hydraulic and after replacing the original pads with some newfren one and polishing the pins I am finding the moving pad is randomly sticking on....it's already burnt the paint on the wheel, anyone got any ideas or had this before?
Is there a thread or link with a step by step guide on setting up this type of brake?
bjhart
Postby Warkton Tornado No.1 » Mon May 30, 2016 12:26 pm
As this is a safety issue, I will try to help, but others might know better than me.
If the new pads are too big, not circular or even too small, then there may be jamming of the moving pad.
It needs to slide in & out with the merest touch of high temperature lube.
If it isn’t that, then it sounds as though the special seal fitted to the bore (usually) has been fitted back to front. By its special shape, it should deform under pressure when the brake is applied, but then when the brake is released, the seal goes back to its proper shape & pulls the piston back with it to prevent the pad dragging.
I hope you can understand what I’ve said here, but if you don’t, I strongly suggest you enrol the help of a professional unless better advice comes about due to your question.
Hopefully, somebody on here will know the precise cure.
