Made side panel battery tray
Re: Made side panel battery tray
Postby shane BBoys » Mon Feb 12, 2024 5:38 pm
roli150lam wrote:how many alloy ones failed? i've only ever seen a photo of one that had failed...allegedly.imo the photo didn't look at all geniune.
i have one of the original alloy carriers,the type with the thumbscrew that makez for easy removal.i'v had it fitted for several years now.never had a problem with it.
Hi.
I have made contact with the guy who made the type you have described, I am waiting on him getting back in tough with me his at least will carry a alarm battery where as the cam lam 1 only fits their small 1 which when I have rigged it up will not light up the spot light that it is intended for; i have contacted them and waiting for a response. The spot light works with the alarm battery with the same wiring configuration!
Cheers Shane.
shane BBoys
Postby roli150lam » Mon Feb 12, 2024 10:32 pm
hi,good luck,i hope you get a reply.
roli150lam
Postby shane BBoys » Thu Feb 22, 2024 5:27 pm
Sorry for the delay.
they said that my lamp needs to be LED which it is, my plan is to hook everything up including the 4 pin regulator and try running the bike and then trying the light? if this doesn't work then plan B!
Cheers Shane.
shane BBoys
Postby shane BBoys » Mon Feb 26, 2024 8:45 am
Well.
Here I am again, so it did not work using the battery supplied so back to plan A not B, I am going to use a 12V 7.2ah gel battery which was my initial purchase for the spot light.
Cheers Shane.
shane BBoys
Postby coaster » Mon Feb 26, 2024 2:35 pm
shane BBoys wrote:Well.
Cheers Shane.
What do you mean by it not working, did the battery not hold charge for long?
The problem with the 5 pin regulator is that it only provides enough current to trile charge the battery, electricity tricles in but gushes out when you connect a load. I have had several full DC converions over the years and even they struggle to charge a battery s well as powering the lights. The type of riding you do is a major factor, town riding will result in little or no chrging if the headlight is on at anything much below 45 ish mph :( Dual carriageways are ok though, on long trips I turn my headlights off on long dual carriage ways to give the battery a chance to recover.
Postby roli150lam » Tue Feb 27, 2024 11:40 am
there is a small business in Saxilby,Lincs.they make quality led bulbs for classic cars&bikes.they do ba21d fit.well worth a look.
classic dynamo&regulator conversions.
roli150lam
Postby shane BBoys » Tue Feb 27, 2024 6:17 pm
Cheers Shane.
Hi.
I fully charged the battery ( not the 12v 7amh this works fine ) the week before trying it out, it is a 4 pin regulator due to my old Indian type ignition. a battery box is being made as I type for the 7amh battery.
Cheer Shane.
shane BBoys
Postby shane BBoys » Tue Feb 27, 2024 6:20 pm
roli150lam wrote:there is a small business in Saxilby,Lincs.they make quality led bulbs for classic cars&bikes.they do ba21d fit.well worth a look.
It is more than likely this is where I got mine from, I have 2 Lucas spots on my Spanish El Toro and they work off a tiny 12v battery that I hooked up as a trial.
Cheers Shane.
shane BBoys
Postby roli150lam » Tue Feb 27, 2024 9:29 pm
who is making the battery box?
roli150lam
Postby roli150lam » Tue Feb 27, 2024 9:31 pm
who is making the battery box for you?
roli150lam
Postby L111amo » Tue Feb 27, 2024 9:34 pm
Sorry to butt inb but what is the name of the place that does the bulbs , cheers liam
L111amo
Postby roli150lam » Tue Feb 27, 2024 11:12 pm
roli150lam
Postby shane BBoys » Wed Feb 28, 2024 8:25 am
roli150lam wrote:who is making the battery box?
You know you cannot advertise on here, looking at where you are from I am guessing you may know him :D
shane BBoys
Postby roli150lam » Wed Feb 28, 2024 12:36 pm
no i don't know him.never been to his shop never bought anything from him.
might be a better option than buying chinese made led bulbs tho.
roli150lam
Postby L111amo » Thu Feb 29, 2024 12:20 am
Thanks for that
L111amo
Postby shane BBoys » Mon Mar 04, 2024 5:22 pm
So here's a weird 1 I was having a tidy up in the garage and thought I would try the smaller battery on my Spanish S2 El Toro where I have rigged up 2 x Lucas spots ready to run off some sort of battery as I'm leaving this 6v for now and it is a long term project, anyhow both have LED lamps no switch as yet and not fuses and they both lit up?
Very Baffled Shane.
shane BBoys
