Youtube Lambretta engine rebuild part 1 to 21
Re: Youtube Lambretta engine rebuild part 1 to 21
Postby kennystag » Mon Apr 25, 2016 1:59 pm
Hi All,
Anybody know if the engine ever ran ok.
Stag
kennystag
Postby coaster » Mon Apr 25, 2016 4:07 pm
kennystag wrote:Hi All,
Stag
I haven't had time to check through them all but the guy has a lot of other stuff including servicing the carb which looked to be up to his usual standard ;)
https://www.youtube.com/channel/UCGojCq ... gjw/videos
Postby johnnyXS » Mon Apr 25, 2016 4:19 pm
coaster wrote:
Bettagetabrettabolti wrote:I wouldn't let him near my washining machine - could be seen as the alternative to Sticky's book! Check out 15 never seen anyone fill a gearbox that way in 45 years of engineering! That's where I have been going wrong!
Bolti
I've just watched 2 and 3 and I'm not sure I can take any more :? The fitting of the selector spring and balls was hilarious :lol: (start of episode 2) I mean I know it isn't the easiest of jobs but it was quite excruciating to watch :shock: Have to admire his dogged persistence though,
:lol: :lol: I saw this video a couple of weeks ago when attempting to fit my selector cursor for the first time. I think it took me 30 seconds.
Just had to go and see if I could beat that time .
https://youtu.be/CpSVmz7aZn0
Whats the best time you can do can you beat 17 seconds ;) ?
johnnyXS
Postby MickYork » Mon Apr 25, 2016 4:49 pm
just had a quick look at this :o . He was fitting the flywheel and putting the cylinder head on.
Timing set at 20 degree and no spring washers on cylinder head.......is the rest as bad as this :? ?
Postby coaster » Mon Apr 25, 2016 9:16 pm
No wavy washer on the rear hub, you don't see him tightening the nut which would be well nigh impossible with the engine on the bench but he did fit the lock plate and used threadlock which implies that he ';though't he'd tightened it enough. Compressing the clutch using a length of wood wedged under his shelf was inspirational :?
Postby HxPaul » Mon Apr 25, 2016 9:41 pm
Rebuilt the engine,put the drive side oil seal plate on,but no halite washer..................and wondered why it smoked so bad when he started it up.
Users browsing this forum: Google [Bot] and 62 guests
