jonalabaster wrote:Hi there, I have a Lambretta LI150 series 3 6v original points system, Italian. It has a battery which powers the brake light, side light and horn. Don’t use it much but the battery goes flat within a couple of hours of fitting after charging. I just took it out for a spin and the lights now only appear to work when the battery is disconnected. Wondering if it could be the regulator as at one point this for quite hot. The fuse isn’t blowing which is strange as if there was a short I would have thought this would happen. Have checked the wires and continuity to the headset which appear fine. I fitted a new switch when the scooter was rebuilt which is an original too. Hope this all makes sense, any ideas?
lam1962brettagg wrote:hi
had a similar problem with my standard 6v li150 DC
the battery would discharge quite quickly. after about three new batteries in the period of about 2yrs i bought a new regulator and have had great charge and same batt for three years or more.
you say yours has an AC horn??
should be a DC i think.
hope this helps
MickYork wrote:put a volt meter across the battery and rev the engine.....you should be getting a tad over 7v. if less you're regulator is suspect, likewise anything over 8v would point to suspect regulator.
Fast n Furious wrote:Ah I see. A 4 pole system.
These old selenium based rectifiers were never very reliable any way.
If I'm reading the drawing correctly, then the headlamp is AC straight off the generator and everything else is DC via the rectifier, battery and inductor. Long time since I worked on a 4 poler so I stand to be corrected.
Rimini still do these regulator boxes for about £100. Ouch.
Perhaps you can get creative by just replacing the old selenium rectifier array with a more modern silicon rectifier diode. Maybe something like the RS Stock No.544-5802 can be successfully grafted in its place? Less than £3. Gotta be worth a try.
