by St George » Fri Aug 03, 2018 4:54 pm
Will a series 2 12 volt engine fit straight into a series 3, will I need to do any mods whatsoever. Will the series 3 exhaust fit it. Thanks.
St George
by HxPaul » Fri Aug 03, 2018 5:27 pm
The only difference as far as fitting is concerned,is the sidecase.If you fit it with the series 2 sidecase,you will have to change the kickstart lever for a series 2 one.You can fit a series 3 sidecase onto the engine then you wont need to change the kickstart lever.
by St George » Fri Aug 03, 2018 6:02 pm
That's cool Paul. Kick starts are cheap enough.
St George
by MK Monty » Sat Aug 04, 2018 10:14 am
Assuming your series 3 is 12V if not you will need to look at bulb and horn swaps and maybe a regulator depending on what its got
MK Monty
