by al pushpak » Thu Apr 19, 2018 1:08 pm
hi, hope this doesn't sound like a daft question but where abouts should the feeler gauges be placed on the endplate when measuring the endfloat on the large gear shim ? thanks for any info
al pushpak
by CHRIS in MARGATE » Thu Apr 19, 2018 4:34 pm
I always make sure the hub is torqued.
The way I was taught to measure in my apprenticeship was to make sure the feeler guage one size below passes and the feeler guage one size above doesn't pass.
by al pushpak » Thu Apr 19, 2018 8:17 pm
Thanks for the info & the pic , much clearer than the one in Sticky manual, cheers
al pushpak
by bazza3004 » Thu Apr 19, 2018 8:26 pm
Does the feelef need to be inserted right up to the shaft as iirc isnt there a 'boss' under the bearing seat or does it only need to go in 10mm or so . Sorry if this sounds like a dumb question.
bazza3004
by Feersum Injun » Thu Apr 19, 2018 10:45 pm
I believe so.... the shim should rotate, hence the gap. Otherwise you'd be measuring from the shim to the plate and the gap would be way to big...
Feersum Injun
by Feersum Injun » Thu Apr 19, 2018 10:47 pm
Also make sure you use nuts and torque them unlike in my photo...!!!
Feersum Injun
by bazza3004 » Fri Apr 20, 2018 1:24 pm
Thank you
bazza3004
Users browsing this forum: No registered users and 101 guests
