Series 1/2 rear tyre fitting
Postby al pushpak » Sun Mar 25, 2018 5:22 pm
Hi , got out on my series 1 today because of the rare occurrence of nice weather :D & coming home I ended up with a flat tyre on the back, luckily I carry a spare & mini pump but I always have to let some air out of the spare in order to fit it because of panel handle bracket on the frame :roll: just wondered what other people do in this situation as no end of twisting & turning would make the spare wheel go on til I let some air out! :shock: thanks for any info ;)
al pushpak
Re: Series 1/2 rear tyre fitting
Postby Scooter Paul » Sun Mar 25, 2018 5:26 pm
What rear shock do you have? The slightly shorter series 3 type will give you this problem. With a series 2 type you should be able to wiggle the wheel out. The difference being the angle of the engine unit. Otherwise remove the rear shock, get a willing helper to lift the rear end whilst you take off the wheel.
Scooter Paul
Postby bike grim » Sun Mar 25, 2018 5:37 pm
Chop the pointed end of the inner prong on the bracket by about 10 to 15mm. Gives you a bit of extra wriggle room.
Postby al pushpak » Sun Mar 25, 2018 5:58 pm
Thanks for the replies, yes I think I've got the later type series 3 shock on so that would make sense to why I struggled :roll: will either have to start carrying a shocker nut spanner or shave a bit off the bracket ;) cheers
al pushpak
Postby HxPaul » Mon Mar 26, 2018 8:57 am
Postby Tractorman » Mon Mar 26, 2018 8:55 pm
bike grim wrote:Chop the pointed end of the inner prong on the bracket by about 10 to 15mm. Gives you a bit of extra wriggle room.
spot on.
