Knowledge wrote:I only have oversize NOS Suzuki pistons, but it is worth noting that the distance between the top peg and the bottom pin positions varies from 30mm to 37mm and 45mm, showing the progression of the piston through its generations.
I would opt for the Mitaka piston that is ER. The quality is good and the ring pegs should be wide enough to miss the inlet port. If you want an old piston to play with, I can supply, but I can’t guarantee that it won’t have a hold in the top.
Happy days.
Users browsing this forum: Baidu [Spider] and 69 guests
