150-200 mag flange
150-200 mag flange
Postby MickYork » Sun Sep 10, 2017 2:31 pm
Can a 150 mag flange be swapped straight onto a 200 casing, or does it need modifying ?
Re: 150-200 mag flange
Postby HxPaul » Sun Sep 10, 2017 3:04 pm
Sticky's manual says that it is possible to use a 150 mag housing on a 200 case but the transfer ports must be machined to fit.
Postby Scooterlam » Sun Sep 10, 2017 3:39 pm
Pretty sure I have an unmatched 150 on my 200.
No issues.
Small losses possibly but not sure I can notice it.
Scooterlam
Postby MickYork » Sun Sep 10, 2017 3:45 pm
Yeah just read Sticky's and there's quite a few if's, but's and maybe's.............might work with some but not with others....... :?
Postby ToBoldlyGo » Sun Sep 10, 2017 4:02 pm
I had a 150 mag flange matched to a 200. It's a simple thing to do. So if you've got one why not take the time to do it properly?
ToBoldlyGo
Postby MickYork » Sun Sep 10, 2017 4:20 pm
ToBoldlyGo wrote:I had a 150 mag flange matched to a 200. It's a simple thing to do. So if you've got one why not take the time to do it properly?
I suspect my flywheels bearing has gone. I have a spare 150 mag housing and was going to build it with new seals and bearings then do a straight swap. The alternative is to re-use the fitted mag housing, which means it will take slightly longer.....no massive problem.
Postby modster79 » Sun Sep 10, 2017 4:30 pm
Usually it's just a case of reshaping the transfer cut out on mag house to the same shape on casing, done it a few times. Basically a 10 minute job with a multi-tool or a die grinder.
modster79
Users browsing this forum: Baidu [Spider] and 45 guests
