Tv barrel
Tv barrel
Postby Cgt75b » Mon May 22, 2017 8:33 pm
Hi folks
Recently I trashed my piston on the C2c amongst other things. This is a cast iron top end 65mil plus bore. So my question is where is the best place to source a piston. It's a proper bitsa the bike a series three with a series two motor.
Any help would be appreciated.
Regards Cgt75b
Re: Tv barrel
Postby Adam_Winstone » Mon May 22, 2017 8:47 pm
Is it a modern 65mm to fit 107mm rod or 60s conversion 65mm designed for use with the TV 116mm rod?
Re: Tv barrel
Postby Cgt75b » Mon May 22, 2017 8:52 pm
Hello Adam
It's the latter pal.
Re: Tv barrel
Postby Warkton Tornado No.1 » Mon May 22, 2017 9:19 pm
I think you may have several options:
Suzuki TS185 pistons spring to mind but check out the compression height. Wiseco do them in Ø65 mm + if OEM are unavailable.
Otherwise, for the cost/hassle involved, you may be best to seek a piston that will fit your bore that is of a similar compression height to the Lambrettas that uses the shorter 107 mm rod.
Admittedly you would require a base packer (no bad thing IMO) & you might have to accept a single ring piston & even have to ‘cap’ the gudgeon pin, but there are advantages to a ‘modern’ piston in terms of strength & reliability.
I hope that all makes sense!
Re: Tv barrel
Postby Fast n Furious » Tue May 23, 2017 2:32 am
The TS185 piston has a compression height of 32.5mm. So, only 2.5 mil difference. 2.5 mil base packer should sort that out.
The Mitaka ones are good and sensibly priced.
Exhaust may need a little rework to fit properly.
Re: Tv barrel
Postby Warkton Tornado No.1 » Tue May 23, 2017 11:24 am
Fast n Furious wrote:The TS185 piston has a compression height of 32.5mm. So, only 2.5 mil difference. 2.5 mil base packer should sort that out.
Fast n Furious is spot on & re-reading my own advice I was possibly trying to offer you more options than you might like :roll: My apologies to both of you!
The Mitaka pistons are indeed very good, but original Suzuki would be my own preference. The only problem I have encountered with Mitaka is the gudgeon pin circlip retaining area breaking up on a TS250 piston. I've never had that with any of the many OEM Suzuki (PE, RM, TS) pistons that I've used. You might have to search long & hard for one, though they do come up on auction sites....
Re: Tv barrel
Postby Cgt75b » Tue May 23, 2017 4:26 pm
Thanks guys for your informed opinions gives some food for thought. I've taken the crank out today and there is a massive amount of side to side play on the rod which I think has contributed to my breakdown.
I may need to entrust it to an expert I think.
Thanks once again
Still searching for the holy grail "reliability from a lambretta"
Re: Tv barrel
Postby rossclark » Tue May 23, 2017 9:49 pm
It's normal to have a lot of side to side on an unshimmed big end.
Did you have shims fitted on the small end?
Re: Tv barrel
Postby Cgt75b » Mon May 29, 2017 4:41 pm
rossclark wrote:It's normal to have a lot of side to side on an unshimmed big end.
Just out of interest how much side to side play is normal?
No shims top or bottom.
Re: Tv barrel
Postby Adam_Winstone » Mon May 29, 2017 6:45 pm
If yours had an original TV crank fitted then it should actually be very little as the early cranks were aligned, although not shimmed, at the big-end. Later assemblies had lots of float at the big-end as the rods were aligned by spacers at the small-end. Most modern cranks have returned to alignment at the big-end but not do it by the introduction of shims.
All of the float info is detailed in most Lambretta manuals.
Adam
Re: Tv barrel
Postby Cgt75b » Wed May 31, 2017 7:00 pm
Thanks for all responses. Hopefully gonna get it fixed up shortly with a Gp crank with the long rod + new piston.
