Anyone seen this before?
Postby rossclark » Sun Apr 09, 2017 10:25 am
Started building a new motor on an new SIL casing (from SR)
Went to fit the gear change shaft and it won't go all the way in. Tried a GP type and the old Li type both with the same result. Ends up about 15 mm out of the casing. Seems like the hole at the bottom is either too tight or not deep enough. Giving it a tap with the hammer and it sounds fairly solid.
Re: Anyone seen this before?
Postby coaster » Sun Apr 09, 2017 11:36 am
104mm on my spare case (also indian but small block) from top of case to bottom of shaft hole 8-)
Postby rossclark » Sun Apr 09, 2017 3:33 pm
Yep, thanks Colin, also got 104mm to the bottom of the hole must be a burr or something in the bore of the hole
Postby rossclark » Sun Apr 09, 2017 4:27 pm
I checked a small block case under the bench and it is the same 104mm and no issue with tightness in that shaft
So it must be something like that. Managed to get it all the way down with a couple of sharp smacks with the copper hammer, but it was very tight.
Got some grinding paste on it and have spent an hour working it back and forward before it was as free as I'd like.
Now rained off for the day.
Postby coaster » Sun Apr 09, 2017 6:32 pm
Ah but it wouldn't be so much fun if they all went together without problems ;) :lol: :lol:
Users browsing this forum: No registered users and 76 guests
