by P D: SC Chester » Thu Mar 16, 2017 10:58 pm
Was thinking of buying a cheap SIL piston as back.
Anyone ever ran a cheap 1 and got away with it? Or is it just a waste of time and effort?
P D: SC Chester
by coaster » Fri Mar 17, 2017 8:12 am
What would it be a backup for? if it's an iron barrel then it would probably get you home albeit at a reduced speed.
by Adam_Winstone » Fri Mar 17, 2017 10:44 am
Depends what it is going in but the standard Mahle 3 ring is actually a very good piston. Best to run just the top 2 rings though.
Adam
by Marty ULC » Fri Mar 17, 2017 1:15 pm
Definitely worth it.
It'll get you home and you won't worry about wrecking an expensive piston in a scored barrel.
Marty ULC
Users browsing this forum: Baidu [Spider] and 72 guests
