S3 rear footboards on a GP ??
Postby corrado » Sun Mar 12, 2017 2:39 pm
Will S3 rear footboards fit on a GP? .... and vice versa.
Looking at the difference in the 2 sets in Sticky's book [page 170] there's very little difference and no mention if the GP boards are Italian or Indian. I'm just guessing that they're Indian and have a flatter curve designed to give extra clearance for the longer finned flywheel cowl on Indian GPs, I can't think of anything else that's different in that area between S3 & GP. So if you're running a shortened fin [or Italian] flywheel & cover then they should fit.
corrado
Re: S3 rear footboards on a GP ??
Postby ToBoldlyGo » Sun Mar 12, 2017 3:00 pm
Unless you're a stickler for detail I always understood that you can fit GP boards on an earlier S3, but not the other way around for some reason.
ToBoldlyGo
Postby Warkton Tornado No.1 » Sun Mar 12, 2017 3:03 pm
I hope I haven’t missed the point of your question. However, here goes:
The floorboards vary due to following the profile set by the side panels. There is a definite kink in the GP panels & consequentially, the floorboards have a similar corner whereas the SIII floorboards have a gentle curve. Having said that, they'll 'fit' but do look a bit sore TBH.
As for the fan cowling clearance, even without an extended cowling, sometimes I have resorted to tweaking the LH floorboard to increase or decrease clearance, dependent upon condition.
Postby corrado » Sun Mar 12, 2017 4:13 pm
Good point, I hadn't considered the side panels, I'd just assumed that it was to do with the flywheel cowls. I'll dig out some boards and panels to see how different they look.
corrado
Users browsing this forum: No registered users and 82 guests
