by Geocamper » Tue Aug 05, 2014 11:16 pm
Running a 42mm clubman into 200gp gearbox. There's a hole on the underside of the gearbox which is for the exhaust bracket to be fixed to with a screw. Could someone tell me what size screw I need to fit the hole?
Geocamper
by peejay » Wed Aug 06, 2014 12:39 am
8mm
by CHRIS in MARGATE » Wed Aug 06, 2014 6:41 am
No thats the tailpipe fixing and thats 10mm and bolt underbeath is 13 mm. Off the top of my head.
by Dimitrios_231 » Wed Aug 06, 2014 8:31 am
M8*1.25 pitch.
Both of you are correct, it is 8mm in diameter and the most common metric spanner sizes used for the head of the bolt, are 13mm and 14mm.
Dimitrios_231
by mickyb » Wed Aug 06, 2014 8:32 am
Tail pipe fixing is 6mm, bracket underneath is 8mm. The bolt heads are 10mm and 13mm respectively
mickyb
by Geocamper » Wed Aug 06, 2014 9:36 am
Thanks guys
Geocamper
Users browsing this forum: No registered users and 85 guests
