Remade headset recommendations..
Postby genolambo » Wed Aug 03, 2016 10:36 am
Hi all..
Possibly looking for a replacement headset for a S3 Li chrome ring model.
Could anyone recommend from where I can get a decent one?
Its an issue with my current headset bottom, the lug for the throttle roller stop. It seems to be worn away. Could anyone measure theres and give me an approx measurement as to what it should be?
Thanks in advance
genolambo
Re: Remade headset recommendations..
Postby ToBoldlyGo » Wed Aug 03, 2016 11:28 am
Try Martin Girvin on FB. Might possibly be on here. Goes by the name of Fatbloke.
ToBoldlyGo
Postby swissdean » Wed Aug 03, 2016 11:43 am
I have one (white), was fitted to my non chrome model and caused headaches...would need painting. i am due back over to the UK end August and can post to you when across, if you cover shipping/want to wait..
swissdean
Postby HxPaul » Wed Aug 03, 2016 6:44 pm
Surely the problem with the throttle stop can be repaired.Try drilling and tapping and a bolt inserted with a peice of bent metal fastened with the bolt.
Postby Warkton Tornado No.1 » Wed Aug 03, 2016 7:55 pm
Post by HxPaul » Wed Aug 03, 2016 6:44 pm
As has been suggested, you can make a stop by using a bolt.
I do so whenever I substitute a gear pulley with the larger radius to give a ‘quicker’ throttle for use with Ø30 mm & bigger carburetors. The longish M5 or M6 bolt fits in the spare hole (Oooer!) with a nut to clamp it in place & the remaining stem hits the nearby casting web to act as the stop.
You should be able to do something similar, whatever pulley you utilise....
Postby genolambo » Sun Aug 07, 2016 10:24 am
Thanks all for your advice and help..
Sorted!
Thanks again chaps :)
genolambo
