Italian speedo cable drive size
Postby 507VBH » Sat Jul 23, 2016 6:27 pm
Hi,
The square profile on the end of the cable that fits into the speedo housing has sides that are 2mm wide. This seems too small for the square socket I can see inside the speedo.
How big should the end of the speedo cable be? It looks like it should be about 2.5mm square.
Thanks!
507VBH
Re: Italian speedo cable drive size
Postby burnside » Mon Jul 25, 2016 10:56 am
Are you using a Series 1/2 inner? IIRC these are smaller at the speedo end whereas Series 3/GP are the same thickness (2.5mm) at both ends.
burnside
Postby terryj » Mon Jul 25, 2016 11:00 am
early ser 3 use a ser 2 speedo cable i know because i keep buying the wrong one
terryj
Users browsing this forum: Baidu [Spider] and 91 guests
