Hi, The stand on my GP sits almost vertical ... not good as a slight push from behind will knock it over.
This is the 2nd one that does it..
is the only answer to reweld the lugs at a slightly different angle?
peejay wrote:mudwing washers between the u-bracket and outrigger will gain you a few degrees, try 2 each side at first rather than heat treatment.
Digger wrote:I've never heard them called that before (thank you Google) I've always called them Penny Washers.....
Digger wrote:peejay wrote:mudwing washers between the u-bracket and outrigger will gain you a few degrees, try 2 each side at first rather than heat treatment.
Users browsing this forum: Baidu [Spider], Google [Bot] and 56 guests
