How do i remove this
Postby pauLI » Fri Feb 26, 2016 3:52 pm
How do I get the race off to enable removal of the dust cover please?
The top text box says
Stickys book appears to show tapping it with a screw driver, the tip of the screw driver is behind a ridge, mine has no ridge
The bottom text box says
This is loose and has a small amount of up/down play between the race above and the fork
cheers
pauLI
Re: How do i remove this
Postby dave411 » Fri Feb 26, 2016 3:57 pm
I took an angle grinder to mine,put a slit in it,the wacked a cold chisel in there,and bang,it split open. :)
dave411
Postby pauLI » Fri Feb 26, 2016 3:58 pm
I was hoping to reuse the race or is that not a good idea?
pauLI
Postby Warkton Tornado No.1 » Fri Feb 26, 2016 4:09 pm
There may be a small hole, or two, that is on the underside of the fork through which a pin punch can be pushed.
If so, you're in luck as you can drift the bearing off.
Failing that, heat up & persuade off with whatever you can use to pry it off, I'm afraid....
Subject to thorough examination, of course you'll be able to re-use it.
Postby pauLI » Fri Feb 26, 2016 4:15 pm
I have the fork holes, so will try that initially
cheers
pauLI
Postby dickie » Fri Feb 26, 2016 4:34 pm
EBay item 172077318459.
I use mine for all sorts of things. Removing crankshaft inner bearing races being one example.
Postby Warkton Tornado No.1 » Fri Feb 26, 2016 4:38 pm
I've never had a problem using them, even 'back in the day' when a pin punch was probably any old nail! So the process should work.
I'd be tempted to clean up your old shield & compare before substituting for the new. The old parts generally were much better quality than the new stuff about these days.
Good Luck.
Postby Dimitrios_231 » Fri Feb 26, 2016 6:12 pm
Dimitrios_231
Postby gaz_powell » Fri Feb 26, 2016 7:24 pm
Back in the day when a pin punch was probably any old nail.........now that could be a thread if it's own !
Postby drivera » Fri Feb 26, 2016 9:23 pm
pauLI wrote:I have the fork holes, so will try that initially
cheers
should be a small hole at the front underneath the race and same at the back , use a small punch and alternate taps front and back with a hammer , will come off dead easy :)
drivera
Postby Knowledge » Fri Feb 26, 2016 10:33 pm
Have a look at the photo in this recent thread.
http://www.ilambretta.co.uk/forum/search.php?keywords=Specialist+tools
I hope this helps
Users browsing this forum: Google [Bot] and 63 guests
