ignition timing
ignition timing
Postby kennystag » Sun Dec 06, 2015 7:02 pm
Hi All
I have just fitted electronic ignition to my GP. I made a TDC tool the same as in sticky's book drilling the centre out an old spark plug. Screwed the tool in the plug hole, turned the flywheel clockwise until the piston touched the tool. Marked that point with tippex. Turned the engine anti clockwise, again until the piston touched the tool, and marked that point with tippex. Found the centre between the 2 marks. Put on my timing disc on to find 19 before tdc. Here is a picture. Your comments please.
Stag
[imgImage][/img]
kennystag
Re: ignition timing
Postby Dimitrios_231 » Sun Dec 06, 2015 7:09 pm
Well done :)
What kit do you have?
Dimitrios_231
Re: ignition timing
Postby kennystag » Sun Dec 06, 2015 7:14 pm
kennystag
Re: ignition timing
Postby Dimitrios_231 » Sun Dec 06, 2015 7:23 pm
I was asking for cylinder,exhaust etc ;)
if it is something highly tuned you can go to 18 or even 17 degrees.
Dimitrios_231
Re: ignition timing
Postby kennystag » Sun Dec 06, 2015 7:33 pm
Hi All,
What I am trying to say, does this all look ok to fire her up to put the strobe on her to double check the timing.
Stag
kennystag
Re: ignition timing
Postby Dimitrios_231 » Sun Dec 06, 2015 7:35 pm
Yes,go for it ;)
Dimitrios_231
Re: ignition timing
Postby HxPaul » Sun Dec 06, 2015 8:27 pm
I dont know if its my eyesight,but I dont see the timing marks.
Re: ignition timing
Postby dave411 » Mon Dec 07, 2015 9:15 am
have a look at the excellent video a few posts down.
dave411
Re: ignition timing
Postby Meds » Mon Dec 07, 2015 9:40 am
Looks pretty good to me
But don't be surprised if there is a difference between static timing and the actual timing when it's strobed.
Sometimes the timing marks on the stator/flywheel can be a bit out.
Good luck
Meds
Re: ignition timing
Postby kennystag » Mon Dec 07, 2015 4:27 pm
Hi hx paul,
The tippex mark to the left is 19 btdc, and the other in the middle is TDC, the other to the right is 20
Stag
kennystag
Users browsing this forum: Google [Bot] and 43 guests
